Order #712266 - Sub250 Oasisfly25 - Oasisfly 25 that trips my vifly v2 smoke stopper everytime
Order Number: 712266
Product Name: Sub250 Oasisfly25
Brand: Sub250
Everytime I plug in a 4s pack on my Vifly v2 smoke stopper on my oasisfly 25 it trips it out. Ive made a very descriptive video but u only accept 20 mbs. I never connected any reciever or air unit i had only tinned the reciever pads with tape over the fc as i always do.
Ive tried my smoke stopper on other quads and checked betaflight.
Sorry to hear about this, could I ask if you have installed your own receiver or O3 Air unit as its likely that there could be a short on one of the solder points/connections (as the pins can sometimes get bent).
Otherwise what can also sometimes happen is a roque solder splatter could of ended up somewhere it was not supposed to be so it may be worth taking a close inspection of your FC to look for any possible shorts or solder blobs, and if you are not sure adding a clear photo or two of your FC could help us to take a look aswell! But we should be able to help you get to the bottom of this issue!
Kind Regards
