Order Number: 715429
Product Name: Hg-Led-M-W38
Brand: HGLRC
When connected the effected LED module it will display the pattern but with glitches in the display, it will continue despite being moved to a different connector which was verified as working by another LED
I have double and triple checked my soldering joints and that it was connected correctly, removed the heat shrink wrap to insure the plug was fully seated, I moved it to a different connection which was verified as working by another LED strip. Made sure no shorts were there
Hi Joshua good day,
Thanks for reaching out to us! Sorry you are battling with these LEDs.
Would you be able to send me a quick video demonstrating the odd behaviour and a few images of the soldered end of the cable onto the FC?
When ever there is an issue with a product which requires soldering, manufacturers always ask for these.
Hope this helps.
David
