Order Number: 716150
Product Name: Flywhoo Fly Lens 75 04
Brand: Flywhoo
I’ve flown 3 flights now no issues today I did one pack flew landed and put new fresh battery in it was saying looking for signal no signal detect and I though ok maybe lost it’s bind so I rebind and it won’t re bind I brought it home flashed again both 04 pro au and goggles 3 at first I got odd screen then black screen then red bar at bottom saying no signal it’s don’t this all the time now I’ve checked my goggles on my 03 au and avata 2 no issues
I’ve re flashed firmware on both goggles and 04 pro au and I’ve put new batteries in I’ve checked my goggles against an avatar 2 and 03 unit both work perfect
I have sent a request over to Flywoo to get their feedback and suggestions as it would seem we have another customer with their Flylens 85 who has basically the exact same issue as you. So we should be able to figure this out and get it resolved for you!
Also in the meantime if yoou can please add a video/photos showing the issue it can help to better understand the issue.
If you are not able to attach, you can use a service such as imgur.com and share the link here.
hi Alex sure ive actually been onto dji that was painful to say the least basically he wanted the code off the air unit told its in a bnf quad se said I can then steer you in the right direction told them I was onto you guys aswel the video and it will will not create a new re bid if you try too neither also during all the chaos of the picture you cannot formate internal storage as its just come up with error too
you can see its like its stuck in some mega low power setting but I fly fine on it today no issues
Flight Alex when landed I then put in next battery and that’s where it all went south
Thanks, just quick question, this issue looks like the issue is with the camera, or the connection to the camera. So if you could double check that its making a good contact that could help isolate the issue, as Ian from MadsRC noticed a similar issue with his O4:
And we also shared another comprehensive video here
All that to say, we should be able to get a replacement camera/cable to you if that is the cause of the issue, as another customer had the same issue as you, but they had a spare air unit, and after swapping the camera it was all working again.
We are chasing this up with Flywoo so will hopefully get a resolution for you soon.
hi I’ve already checked that as I tune into Ian channel every Sunday this is the pro version too and that issue Ians raised in daily the lite version
being honest id rather return the whole quad I don’t
want to start breaking down a quad I bought bnf that was the whole reason I bought is and the additional no way I can return it you look at it and take it form there its £400 paper weight atm
Hi Mark good day,
I can completely understand that, and again I am really sorry about the inconvenience this has caused. Please can you send it back and we can take this up with the manufacturers separately, while we get you sorted out.
Please return everything for the kit, box, packaging, any instructions or paperwork. And can I ask you let us know when you have sent it so we can be on the look out for it?
The official stuff is below:
Your RMA number
A link to our RMA form
Hope this helps.
David
Morning David than you I bought 4 additional batteries for it to shall I keep hold of them or return them as with package ?
Kind regards Mark
ill keep hold of the batteries David all boxed up gets collected via RM tomorrow
Hi David please find the tracking info for the quad returned as per your advice hope we can this resolved one way or another kind regards Mark .
Hz256636425gb
Hi Mark,
Thanks for providing the tracking info. We’ll look into this and keep you updated.
Let us know if there’s anything else we can assist with.
Best,
Isel
Unmanned Tech
Hi just seeing if you have any updates please ?
We are just running a few more checks to see if we can resolve the issue, otherwise we do have replacements on the way form Flywoo to send one out as soon as they come in We should have any update for you shortly. We have just had a few delays due to some internal server issues with our website so alot of us have been spending some time to resolve that issue (which is also why our website has a new look, as our old website theme was causing some memory leak issues slowing everything down)
Kind Regards
Sorry about the delays in getting back to you, we are still waiting on our replacement stock to arrive, so as soon as it get here we can send you a new drone. They should get here in another week or so.
Otherwise since thee issue occurred within the first 30 days, we can issue a refund if you prefer? Just let me know.
Kind Regards
Hi Alex I will wait for a replacement thank you it’s a great drone TBF .
Thanks once again Mark
Hi Any updates please ?
I am sorry about the constant delays with this replacement. We were told around 22 days ago that Flywoo shipped our order (which is why I previously said that we would get them in around a week), but it turns out the only shipped part of our order (just not thee Flylens 75) and after other communications with them have had some motor supply issues, but they should get the items sent out to us soon. So now the ETA is 24th March.
Given the constant delays, if you do prefer to order an alternative drone, I am happy to issue a refund for you instead, but otherwise the replacement will be sent out to you as soon as the new ones arrive!
