Order Number: NOT TO HAND
Product Name: Geprc Cinelog 25 V2 Analog
Brand: GEPRC
im looking to Upgrading the Geprc Cinelog 25 V2 which i have purchased from yourselves from analog to Dji o4 pro. Do you have a kit or a conversion pack to get it all installed thanks, Vinny
Kind regards,
Kind regards,
Hi Vinny good day,
I did a quick search and found this:
I’m just not sure if this will fit the analogue frame as I would think this was the digital version originally and then updated from O3 to O4.
If you have a printer, possibly print it out and see if it fits.
In the meantime I will ask in the warehouse and see if anyone knows if there are any frame differences between the analogue and digital versions. We don’t have the digital one in stock at the moment so I cant compare them side by side.
Hope this helps.
David
Excellent, would appreciate your help in to the upgrade thanks!
Kind regards,
Hi Vinny good day again,
I cant find a consensus on whether or not there is a differnec between the frames, but what I completely forgot about was the DJI O4 “lite”
This will fit, as the frame has 20X20mm and 25.5X25.5mm mounting options. The DJI O4 “lite” is 25.5X25.5mm mounting, its also much cheaper than the Pro version.
Here is a link to the O4 Lite for refernce:
https://www.unmannedtechshop.co.uk/product/dji-o4-air-unit-digital-fpv-system-04-lite/
I also found adaptor which will sort out that issue, please ind them attached.
If you don’t have access to a 3D printer we can print them for you, just follow this link, upload the files and select what ever material, colour and quantity you want:
Hope this helps.
David
(attachments)
DJI O4 Air Unit Cam Adapter.STL (702 KB)
DJI O4 Air Unit Cam Adapter_Offset.STL (822 KB)
Hey thanks again i had considered the o4 lite, but heard a lot about the issue of it needing 1-3s power and Geprc cinelog 25v2 is on 4s and people having issues
Kind regards,
Hi thanks appreciate the help, could you advise on the material options you have for both the files for printing in black, and price please, as i have no idea thanks.
Kind regards,
We can print in black TPU, PETG, or PLA, for this part its probably best to print it in TPU. The price will be around £3-5 including any setup fees. But to order you will need to place this on our website - https://www.unmannedtechshop.co.uk/3d-printing/
Kind Regards
Do you know if and when you’ll be stocking the Betafpv meteor 75 pro o4 version please,
Kind regards,
We have some on order, but in our experience its really hard to get a confirmed delivery date form BetaFPV, sometimes its 1 week, other times its 6 weeks. But usualy its around 2-4 weeks! Sorry I cant be more accurate, but I can confirm they are on order with BetaFPV, so we will get them as soon as possible!
Kind Regards
