Order Number: UT-708969
Product Name: Tbs Lucid 12s
Brand: Team Black Sheep
Just need to know what pad is signal from reciever only shows gnd tx rx and Pwm don’t know which one is signal as no manual
Looked for manual nothing else as don’t want to connect until know what pad to use
Hi Jason good day,
Thanks for reaching out, I am not 100% certain, to be honest!
I have reached out to TBS and asked for clarification.
As soon as I hear back I will let you know.
David
Hi Jason good day,
TBS responded saying that the Rx and Tx pads are for the crossfire signal.
Hope this helps.
David
The Pwm pad is signal.
There is a manual for it in the tbs lucid esc’s manual
Ok.
So have tried esc now signal connected to Pwm
Motor spins
But when connect to computer just get initializing doesn’t finish.
When select port shows no compatible devices found
Had a neutron am32 esc from you that connected.
Hi Jason good day,
I’m sorry you are struggling with this ESC.
That sounds like a driver compatibility issue, do you have the updated and correct drivers installed for that ESC?
Hope this helps.
David
I have now connected it with the downloaded configurator
Can’t connect to the online configurator
Would it need a different driver than all other esc’s and online configurator
Where would I find latest driver if needed.
J
Hi Jason,
Sorry I meant the drivers for the FC. I’m assuming you are using passtrhough to speak to your ESC? If you have used the same FC and connected to a different ESC, then you have the correct drivers installed for that FC. I would just install both sets of drivers to cover all eventualities of FC you might run into.
This will explain the issue you are having in quite a bit of detail:
https://www.youtube.com/watch?v=V2PDL7pwbZo
Let me know if this fixes the issue you are having?
David
No fc
Its for a plane
Just connecting signal to usb adapter to computer
It sees it in downloaded configurator
Hi Jason,
Honestly, I have never connected an ESC to a configurator without using an FC or arduino and pass-through.
This is a really useful guide to AM32 using that method:
https://www.youtube.com/watch?v=VCIpMOESqmw
Besides the pass-though aspect of connecting to the ESC, the below list might be something worth checking:
USB cable does in fact carry data
ESC is powered with sufficient external voltage
Hope this helps.
IF there is anything else I can assist with, please do let me know?
David
