Order Number: (#UT-717013-WH/OUT/52290)
Product Name: Darwinfpv Tinyape
Brand: Darwin FPV
I jave battleld through express lrs setups, configured betaflight everything works to the best of my very limited knowledge the the throttle will not spin up the out put is working on betaflight, but on o the drone when armed amd on flat surfaces
This is my first drone so this is the bit i need help with
Hi Toby good day,
No problem, lets get this sorted out for you, before we start, please just always make sure you have removed all of the props from your drone when bench testing and configuring. If you bump the throttle or those motor hit full throttle for some reason, we don’t want it flying around inside.
Betaflight has built in some protection feature which prevent the motors from starting up under certain conditions, this is for the exact reason I mentioned previously. Those little props can cause some serious damage.
Maybe check in betaflight to see how this is configured for your specific FW version of Betaflight.
Than do the motors spin up in betaflight when in the motors tab?
And can you see your other channels coming through from your radio on the output tab?
Hope this helps.
David
