Order #- UT-721144 - - Flywoo Flytimes 85 - Faulty motherboard
Order Number: - UT-721144 -
Product Name: Flywoo Flytimes 85
Brand: Flywoo
When I try to connect the drone to betaflight it just says connecting the faild to open
I’ve tried the cable that comes with the drone plus 2 of my own and it still comes ups failed to load or waiting for connection and it doesn’t do anything else
Hi good day,
Have you got the correct drivers installed for your device? This is usually the number one reason for getting this error, else a faulty cable, which you have eliminated as it would seem.
Hope this helps.
David
Hello, yes I’m sure they are correct it’s the same one as I use on all my other fpv drones it’s just this one that doesn’t connect
Hello, I’ve just installed the other drivers from betaflight and it’s still not working
Hi good day again,
I’ve sent your comments and photos through to Flywoo in the mean time to get their comments.
Have you flown this drone at all, does it power up?
Have you tried powering the drone while connected to your PC?
I would always suggest removing props while testing indoors.
David
Hello, no i haven’t flown it at all, it powers up with a battery plugged in but I can’t set the controlls on betaflight because the drone doesn’t connect, that’s the only problem with it it’s not connecting with betaflight it keeps coming up communication failed. Other than that the air unit works but I can’t do anything with it
Hi good day,
Flywoo have acknowledged receipt of the email I sent through to them, one of their engineers is having a look through the details you supplied me.
As soon as I hear back from them I will update you.
David
Ok thank you, I have been talking to a drone YouTuber and he told me a phone app to try speedbee and it’s connected through that but I got to see all the ports and stuff and I don’t know what they are ment to be on, I’ve updated all the drivers what betaflight says to do and it still don’t work on that but I can connect through my phone
I’ve been talking to a drone YouTuber and he has helped me sort that drone out now, all sorts of headaches with it but it’s working now, thank you
Hi good day,
I had the following response from one of the Flywoo engineers, it seems to be a simple fix:
The customer seems to be using a handheld computer to connect. Please make sure that the data cable he uses has a USB-A interface. The USB-C to USB-C data cable is not compatible with our FC.
If you have any further questions or need additional assistance, please feel free to reach out to me directly.
I hope this does simplify things moving forward.
If there is anything else I can assist with please do let me know.
David
Hello, I’ve got an inflight nazgul Evoque f6d V2, after a few minutes of flying I keep getting Rx loss and it just falls out the sky, what could be causing it, thank you
