OSD operation with Chaos fpv200 and matec F-411
Apologies if this is an obvious question …
If I use this VTX/camera combo
https://www.unmannedtechshop.co.uk/fpv200-hs1177-camera-and-chaosfpv-vtx-bundle-pack/
with a Matec F-411 wing, can you confirm that the OSD from the controller will be overlaid correctly on the video signal?
Many thanks
Rob
yeah… you may have to cut the video wire.
Take the video wire (yellow) from the camera and attach it to Cam In on the FC
and the video wire from the VTX (yellow) and attach it to Cam Out on the FC
Ask as many questions as you need
Hi Jason
Thanks so much for your reply, order placed!
Rob
