tried flashing new pro V3 last night using Win 10 …thought I had it but never got beyond message ‘erasing’. waited good three minutes but no other message. After about a dozen attempts holding boot button down while powering up via USB no longer saw DFU but just COM. Then Boot button seems stuck down! Anything I might try to remedy all and get this new board flashed with iNav? Normally run Linux Mint so am going to try that today instead of WIN10. Just think that stuck down boot b will be a problem! Note: tried Betaflight to flash as someone on forum said he had luck doing that after iNav flashing failure and Betaflight indicated read only and he said it got beyond that and successfully flashed…then he went back to iNav and then it also succeeded. No such luck for me! With Betaflight never saw DFU. only COM or Manual…nothing but stuck in th ether…where next?
Related topics
Topic | Replies | Views | Activity | |
Booting up issue of omnibus f4 sd | 0 | 1885 | 28 April 2021 | |
Omnibus F4 V2 Bricked on first flash | 10 | 16386 | 20 May 2017 | |
Omnibus F4 V3 pro (install the same but new board) | 5 | 2138 | 8 August 2018 | |
Omnibus F4 Pro Flight Controller V3 failure | 12 | 4101 | 28 October 2019 | |
Help Flashing an Unknown F3 Board with NO Boot pads (now identified as a Teeny 1S F3) | 15 | 6524 | 5 February 2019 |
