Problems with Remzibi OSD and GPS
Very simply I can’t get it to work properly.
The OSD has the latest firmware and I have managed, eventually, to upload a .bin file which is what you see heads-up.
Initially the GPS on the heads-up shows all zeros which I guess is because the GPS has not yet found a satellite. If I disconnect the GPS all the other values work (voltages etc).
I have connected the GPS to u-centre and this shows the GPS working and finding a fix in 3D.
If I plug it all back together again I get no OSD output at all but I do get camera images.
If I then reload the firmware I get OSD output but nothing from the GPS.
I have looked at the settings for the GPS but I am not sure how these relate to the OSD.
If anyone has any ideas I would be grateful to hear them.
Regards
Dave
My initial thought is that the GPS module has not been setup properly for Remzibi OSD (or the Remzibi OSD settings for the GPS are not correct). I would first try to look at the GPS setup screen on the OSD config tool :satellite: .
Otherwise it seems that both the GPS and OSD are working
I’m not 100% sure how to check the GPS or which combination of connectors to use. Do I need to change the baud rate, if so, how?
Dave
