Product Name:
Brand:
I want to use a wireless trainer set up with two Radiomaster Tx16s radios so do I need an external RF module and if so, which one? Most of my receivers currently are FrSsky but can easily be changed if necessary.
You do not need an external TX module to use a trainer; you just need two radios. The main one that is paired to your aircraft is set as the master, and then the second one (that the student is using) is connected to the master radio (via wire or wireless).
Then you assign a switch on the master radio that will let the student take control, allowing you to take over if needed by flipping the switch back to take control.
Hopefully this will help
