Setting jumper t lite up for dsm2
Hi guys gotta qx95 binded to jumper t lite I just need a hand setting up the jumper n quad to clean flight IV already tested the old version of clean flight and that works with the quad grateful for any help thank you.
Hi, its pretty hard to help with very outdated hardware that is no longer supported, but here are some suggestions:
To set up your Jumper T-Lite with the Eachine QX95 and Cleanflight, follow these steps:
  1. Model Setup on Jumper T-Lite:
  • Power on the Jumper T-Lite radio.
  • Press and hold the menu button to enter the model setup.
  • Create a new model by selecting an empty slot and naming it appropriately
  1. Binding the Receiver:
  • Depending on your receiver type, you might need to use a bind plug or set a command in the CLI (Command Line Interface) of Cleanflight or Betaflight.
  • For Spectrum receivers, you can set the CLI command set spektrum_sat_bind to 9 or 5 to start the binding process, and then set it back to 0 after binding.
  • Turn on the internal RF module on the Jumper T-Lite and select the appropriate protocol (e.g., DSM2 for Spectrum receivers)
  1. Connecting to Cleanflight:
  • Connect your QX95 to Cleanflight via USB.
  • Ensure the correct COM port is selected and connect the software to your flight controller
  1. Configuring in Cleanflight:
  • Navigate to the “Receiver” tab in Cleanflight to ensure that the transmitter sticks are correctly mapped and responding.
  • Set up the necessary flight modes and arming switch in the “Modes” tab. Assign switches on your Jumper T-Lite for arming and flight modes like angle or horizon
  1. Testing:
  • After configuring, test the setup by ensuring all controls respond correctly and the quadcopter arms and disarms as expected.
These steps should help you set up your Jumper T-Lite with the QX95 using Cleanflight. If you encounter issues, check your receiver’s binding process and ensure all firmware and software are up to date.
I have binded it it’s the channels I’ll retry again thank you honestly I really need it lol.
In clean flight I can’t get the green tab to come on on arm not done modes ect before.It’s bound tho so changing my inputs mixes from aert to taer and in clean flight in the receiver tab to changed from aert to taer my channels messed up my thrust went from my left stick to the right stick heard ppl reversing channels I did try not sure what to do is it invert in the jumper t lite in outputs I tried that didn’t work so I went back to aert n channels ok again they work on aert but not taer so ? Does the spectrum receiver choose it for me I’m not sure it’s a dasmicro receiver dsm2 by the way I may have set this quad up wrong thank you for helping.
I’m new to clean flight ect lucky id it on my old laptop.only flew bugs 3 n syma x5c1 so not clued up but good thing is by getting stuck I learn so easier next time I hope as I’m on the jumper opentx other guys set up with there spectrum tx on YouTube there’s none for opentx on the qx95 setting up so I’m bit lost on my jumper setting up nobody to copy you get me. appropriate you time cheers.
