Is there anywhere to buy these cables? Or even make them?
Am no expert , but ,
They look like jst connectors.
You need to measure the distance between pins.
Then search jst .
Yours will be jst-##
I would guess yours are jst -xh
Unmanned tech have some jst types .
If the pitch is 1.25mm then these are Molex series 51021 Picoblade
If the pitch is 1.0mm then JST SH range
Links to both data sheets below
Hope this helps
Steve
JST SH 1.0mm_(14-08-05).pdf (91.8 KB)
