Sonic Modell mini AR wing setup?
I am in the process of trying out an FPV wing. Construct has been super simple but can anyone suggest a guide that covers binding and configuration of the transmitter and setting up the servos? I am using the following;
FS-IA6B receiver
FrSKY QX7 transmitter
Many thanks!!
your going to need to change the Rx (FS-IA6B) it wont work with your Tx
Thanks very much indeed - that might well explain my lack of progress so far! Will change the module after a bit of research for a more suitable one!
Woodsy
Rather than change the the rx I have used an old TX that now binds with the original rx. Does anyone have further info on the servo and channel set up to get the wing into the air?
