SpeedyBee F405 V3 Bls50a Not working on battery only on usb
Order Number: 696454
Product Name: Speedy Re F405 V3 Bls50a 4 In 1 Flight Stack
Brand: SpeedyBee
Was working fine and after installing flew fpv went and changed battery and then not working but works on usb c when connected and no battery voltage showing on beta flight and only 0.01v when usb plugged in
Was all working fine and flying fine boards updated all ok went to change battery and then didn’t work
Hi good morning Harlee,
I’m really sorry to hear about the troubles you have had with your stack.
Would you mind explaining in a little more detail what the issue is that you are experiencing?
Is it just an issue of not reporting the correct voltage in OSD or are motors not spinning or something else?
David
Hi thank you for your reply
I’ve been looking in line and asking people and it keeps coming back to the voltage regulator has gone stop working the stack only works when plugged into beta fight via usb suppling 5volts to the board when the usb is unplugged and the battery is connected only two beeps and no lights motors don’t even twitch hope this helps
Hi sorry
Regards
Harlee
