I’m having a bit of a nightmare with my Taranis x9d plus. in the model set up screen I can only select XJT D8-D16 -LR12 but I do not have XJT model. I used to see D8 D16 without XJT along side I am at a complete loss as to what is going on. flashed firmware to latest 2.3.9 still no joy. please can somebody help??
I cannot bind to any receivers at all this is my biggest problem.
Open tx I’m new to all this flashing firmware stuff never had to do this back in the servo days. I think I might be to old for this now lol. Am I not updating the firmware in open tx ? If this is the case were would I look to find out I’m currently looking in the version screen on the taranis
plug radio in computer go to sd card delete all and put firmware and sd contents on sd card .
hold both trims ( rudder and roll) to centre and power on you should be on boot mode just flash firmware.
you will need correct firmware for receivers you are using, i always download to taranis and use wire in JR port to upgrade receiver.
Hi dale sorry for the late reply I’ve not been well at all. Managed to re install the firmware and flash the receiver and it worked a treat. I can’t thank you enough for all your help with this issue thank you so much.
