Help!!! my Taranis QX7 will not bind to my X4R frsky receiver what can I do
I downloaded some furmwear for the xjt module and wrighten it to my radio and it didnt work so I did a factory reset on my radio and redid the furmwear updata to the new opentx 2.2.2 and now my radio will not bind to any receiver that I have what can I do
Did you turn on the Receiver while holding the Bind Button?
Could you tell us how you went through the binding process? Maybe you did something wrong there
Did you set the correct Receiver Options in your taranis? (D16)
I never had Problems with this Order:
Putting the Receiver into bind mode:
Enabled the Bind Function of the Radio (about 5 sek)
Disable the Bind Function
Turn off the Receiver.
