Tattu 2305 2450KV Brushless Quadcopter Motors Test
From MQTB:
Tattu has been an active member of the miniquad community since the early days, but this is their first foray into the motor world. Tattu 2305 2450KV Brushless Motors are made for FPV Racing drone. Each quadcopter motor has been carefully balanced and tested in the factory. Tattu 2305 2450KV motors are mainly suitable for 180-250mm quadcopter frame, the compatible propeller sizes are 5040 / 5045 two-blade or three-blade propeller, they made for FPV Racing drone. This is an interesting motor as a first entry as it bucks a few of the current trends in the dominant motors on the market.
https://www.genstattu.com/media/catalog/product/cache/1/image/800x800/9df78eab33525d08d6e5fb8d27136e95/t/a/tattu_2305_2450kv_brushless_quadcopter_motors_03_1.png
There is a test about this motor by Miniquadtestbench.
  1. The stator size is right in the middle at 2305, a bit smaller than the popular large motors, and a bit larger than the popular small motors.
  2. The weight is right in the middle as well, coming in at just under 30g. This seems to be a motor of the middle ground on just about every front, with a fairly large air gap, square magnets, and multi-strand windings.
  3. The shaft is retained with a c-clip, but it does retain the stronger single-piece hollow shaft design.
  4. The machining quality and smoothness of this motor are top notch, with excellent finishing and no play.
Results
The results here are reflective of the middle ground this motor seems to occupy; very solid performance, especially for the smaller stator size and conservative kV. The kV tested a tad lower than advertised coming in around 2390kv. One of the most noticable things about these results is the relatively flat performance across the range of props, only showing about 100g difference between the lighter 5″ props and the heaviest 5″ props. This is indicative of the larger air gap and shorter stator, where the lower torque loaded props respond well to the kV and the heavier loaded props bog the motor down a bit. That being said the performance here is very comfortably in the middle range, easily clearling 1300g on the mid to heavy load props, and staying around the 1200g mark even on the light props. It is also interesting to note that this motor barely got out of the low 30A range even on the heaviest props. It seems clear this motor was targeted towards that middle space of the average user, a pilot looking for a mid-weight motor that is usable on a broad range of props and a broad range of flying styles without being over-powered or killing the battery. This seems to have it the nail on the head for a general use, broad application motor that just about any pilot can find a use for.
Tested KV: 2390kv
Weight: 29.7g
Stator W: 23mm
Stator H: 5mm
Test Environment:
XRotor 40A ESC
Timing: Med-high
Dither: 7
PWM: Damped Light
Venom 60A Power Supply
2Farad Caps x2 in Series
Custom Datalogger
TI TivaC Launchpad
Allegro ACS758-200B
Voltage Divider
EagleTree eRPM Sensor
Custom Thrust Stand w/ HX711
4 ms logging rate
Atmospheric Data (Typical)
Barometric pressure: 29-30 in
Ambient Temperature: 70-74 deg F
Humidity: 50-60%
https://i1.wp.com/rcfpvplane.com/wp-content/uploads/2017/09/Tattu-2305-2450KV-Brushless-Quadcopter-Motors-Test.jpg?resize=768%2C447
https://i0.wp.com/rcfpvplane.com/wp-content/uploads/2017/09/Tattu-2305-2450KV-Brushless-Quadcopter-Motors-Test-And-Review-01.jpg?resize=768%2C294
https://i0.wp.com/rcfpvplane.com/wp-content/uploads/2017/09/Tattu-2305-2450KV-Brushless-Quadcopter-Motors-Test-And-Review-02.jpg?w=600
https://i2.wp.com/rcfpvplane.com/wp-content/uploads/2017/09/Tattu-2305-2450KV-Brushless-Quadcopter-Motors-Test-And-Review-03.jpg?w=600
https://i2.wp.com/rcfpvplane.com/wp-content/uploads/2017/09/Tattu-2305-2450KV-Brushless-Quadcopter-Motors-Test-And-Review-04.jpg?w=600
https://i2.wp.com/rcfpvplane.com/wp-content/uploads/2017/09/Tattu-2305-2450KV-Brushless-Quadcopter-Motors-Test-And-Review-06.jpg?w=600
Looks interesting, what is the RRP for this motor?
Also I am a little sceptical of MQTB results (although he is very honest and does a great job) some manufacturers (T-motor) send him special prototype motors that are different to public release motors , so when customer start buying them, they dont get the same performance.
These are the RRP for this motor on Tattu,
US: 75.96$;
EU: 75.6€
