I have a new LiPro balanced charger at start of charging the TEMP warning starts to flash and stops the charging, any ideas on how to remedy this fault??
Could you please give me some more details on what charger you are using, what battery and what settings are you using?
I am using a iMAX B6 LiPro Balanced Charger on a High Discharge Li-Po battery 2200mAh. Set to 2.3a and 11.1v
Does your battery get hot when it is charging? If so then its likely that your battery is damaged so I would be very careful when charging as it could explode. But if it only slightly warm when charging then it is probably just a faulty temperature sensor. But please be very careful as charging batteries that are faulty can be very dangerous.
