I found this on a fb group. Is this a good trick for Yuneec Q500 batteries?
I’m am not sure how that will help, I guess by doing that it’s a hack to get all the cells to balance properly, but it you are using a half decent lipo balance charger from the start this will not be needed? What do you think?
I think this post’er is thinking of NiMh or NiCd packs where they have to be cycled occasionally to keep them ‘conditioned’ and able to deliver power quickly, a bit like making a 10C LiPo into a 30C
As Alex @unmannedtech1 has said in last post a modern charger will balance cells easier and LiPo’s do not need ‘conditioning’
This takes me back 35 years to when I raced 1/10th electric cars at GEC Stychfields, one of the top clubs in those days. lot of water under the bridge since then
Steve
Lipo battery should always keep its power at least 20%, so you need often charge your lipo, and avoid over discharge(discharge over 80%). Use the right way to charge your lipo(official charger or some other good charger). I think these are enough.
