TX/RX Recomedations
Advice on either a Frisky X14s or X18s.
Ive had RC Cars for years but this is the first step into flying and really would appreciate some help.
I have a ZOHD Drift and a TBS Caipirinha that I am building, and want a TX to future proof me and Im drawn to the Frsky range. I would like to eventually go FPV and long range but will be starting with just LOS with no FPV.
What would be best suited? Frsky X14S? or FrskyX18S?, I definetley want the ball bearing gimbals, but need to understand the range.
Would the X18 give long range so that I wouldn’t need Crossfire? Im not bothered about the screen but more so about the dual 2.4/900hz?
Also I need the smallest RX for the drift what RX would you recommend, and what antenna would be best?
I appreciate your help, as Ive confused my self enough now after hours of you tube and online research!
Many thanks
Hello Justin,
When considering a transmitter for your ZOHD Drift and TBS Caipirinha, especially with future plans for FPV and long-range flying, the FrSky X14S and X18S are both excellent choices. Here’s a breakdown to help you decide which one might be best suited for your needs:
FrSky X14S vs. X18S## FrSky X14S- Gimbals: High-Precision Hall-Sensor gimbals with 10 ball bearings.
  • Dual Band: Supports dual 2.4GHz frequencies simultaneously for improved range and reliability.
  • Memory: 512MB internal flash storage.
  • Gyroscope: Built-in 6-axis gyroscope sensor.
  • Weight: Lighter and more compact, making it easier to handle.
  • Price: Generally more affordable than the X18S.
FrSky X18S- Gimbals: Similar high-quality gimbals but may have additional features in the S version.
  • Dual Band: Also supports dual 2.4GHz and has the capability for 900MHz, which is beneficial for long-range flying.
  • Memory: Typically includes more advanced features and storage options compared to the X14S.
  • Screen: Larger touchscreen interface for easier navigation and setup.
  • Range: The dual-band capability (2.4GHz/900MHz) allows for extended range, potentially reducing the need for Crossfire systems if you plan on flying longer distances.
Recommendation
If you prioritize long-range capabilities and want to future-proof your setup, the FrSky X18S would be a better choice due to its dual-band functionality and enhanced features. However, if you are looking for a more budget-friendly option that still offers excellent performance, the FrSky X14S is highly capable and suitable for your initial LOS flying.
Receiver Recommendation
For your ZOHD Drift, consider using the FrSky R-XSR or XM+ receiver:
  • R-XSR: Compact size, supports telemetry, and has a good range. It’s a great choice for small aircraft.
  • XM+: Even smaller than the R-XSR, ideal for lightweight builds where space is at a premium.
Antenna Options
For antennas, use the standard antennas that come with these receivers. If you want to upgrade:
  • Consider using a Diversity Receiver Setup, which can enhance signal reception by using two antennas (one vertical and one horizontal).
Conclusion
Both transmitters will serve you well as you transition into flying. The choice between the X14S and X18S depends on your budget and how much you value long-range capabilities versus initial features. For receivers, the R-XSR or XM+ will provide reliable performance in your micro drone setup.
Best,
Isel :slightly_smiling_face:
Unmanned Tech
