Velocidrone Throttle Error
Hello,
I have been using velocidrone with the DJI FPV CONTROLLER for about a month and everything has worked well. However, today I got a weird error. When I push the throttle up fully on the controller it snaps down, not physically but on velocidrone. Which means I fall when applying full throttle, which is very annoying to fly with. Pitch, roll, and yaw work fine. I have played around with the settings on velocidrone but this has not resolved the issue.
Any help would be really fantastic. Thanks.
This is a known issue in the Dji firmware. Nothing I’m aware of that can be done radio side.
You might be able to put a limit in place within velocidrone however
OK thank you. Would this error occur in real life, when flying a real drone? (I am building my first drone soon).
Not in my experience it’s only in the sim
OK, thank you for the help
The problem has been fixed with the firmware update for the DJI fpv system, v01.00.06.00
