Hello so I got everything on my drone working right except the receiver. I have a flysky fs-i6 remote trans and a fs-ia6b RX with it and realized I may need a new receiver. The FC I’m running is this : 9g 30.5x30.5mm Omnibus F4 Flight Controller AIO OSD 5V any ideas what receiver would work with my flysky and this flight controller? Or if my receiver works which pins should I be running it to?(my guess is one of the rx ones but not sure which one) Here’s the pinout for my FC:
You can use ur Ia6b as Receiver.
Just connect the red wire to a 5v output, the black wire to GND and the data cable (yellow or white) to the PPM Port.
If you dont want to use PPM as protocol then connect the data cable to a spare UART.
You can read here about the configuration in Betaflight:
