Wizard x220s help needed
Hi All
sorry but straight in with a problem on my first post.
bought a x220s and started to set it up, its all gone wrong!
it was all working out of the box but i loaded betaflight and done a firmware upgrade.
lost all the switch setting but i managed to get the arm switch working and it arms but no led lights at the back and when i put the throttle up the motors spin at different rate until they all start to speed up uncontrollable, even when i move the right stick the motors spin like mad
thanks dave0
Couple questions first…By updated firmware, do you mean you updated Betaflight, or you flashed your fc? Do you know what version of Betaflight you are running? Go to the CLI tab, at the bottom type in the word “version” without the quotes, and hit enter. Copy and paste it here so I can take a look.
hi
thanks for the reply,i tried to update the firmware on the fc, i am using version 10.6 betaflight.
i managed to load the previous config file and it seems to be working and now i have sorted the switches it seems to be all good, leds all working
below is the config file but the only thing i am not sure about is the fail safe
diff all
version
Betaflight / OMNIBUSF4SD (OBSD) 4.0.0 Apr 11 2019 / 07:31:36 (9ad2cc844) MSP API: 1.41
start the command batch
batch start
reset configuration to default settings
defaults nosave
board_name OMNIBUSF4SD
manufacturer_id
mcu_id 0035001b4848500c20393743
signature
name
name X220S
resources
timer
dma
mixer
servo
servo mix
feature
feature -RX_PARALLEL_PWM
feature -AIRMODE
feature INFLIGHT_ACC_CAL
feature RX_SERIAL
feature MOTOR_STOP
feature LED_STRIP
feature DISPLAY
beeper
beeper -GYRO_CALIBRATED
beeper -RX_LOST
beeper -RX_LOST_LANDING
beeper -ARMING_GPS_FIX
beeper -GPS_STATUS
beeper -ACC_CALIBRATION
beeper -ACC_CALIBRATION_FAIL
beeper -READY_BEEP
beeper -DISARM_REPEAT
beeper -ARMED
beeper -SYSTEM_INIT
beeper -ON_USB
beeper -BLACKBOX_ERASE
beeper -CRASH_FLIP
beeper -CAM_CONNECTION_OPEN
beeper -CAM_CONNECTION_CLOSE
beeper -RC_SMOOTHING_INIT_FAIL
beacon
map
serial
serial 5 64 115200 57600 0 115200
led
led 0 0,11::AOI:8
led 1 0,12::AOI:8
led 2 0,13::AOI:2
led 3 0,14::AOI:2
led 4 0,15::AOI:2
led 5 15,11::AOI:8
led 6 15,12::AOI:8
led 7 15,13::AOI:2
led 8 15,14::AOI:2
led 9 15,15::AOI:2
color
mode_color
mode_color 5 0 9
mode_color 5 1 11
mode_color 5 2 2
mode_color 5 3 13
mode_color 5 4 10
mode_color 5 5 3
mode_color 6 0 2
mode_color 7 0 0
aux
aux 0 0 0 1700 2100 0 0
aux 1 2 1 900 1250 0 0
aux 2 13 3 1700 2100 0 0
aux 3 30 1 1300 1700 0 0
aux 4 47 1 1700 2100 0 0
adjrange
rxrange
vtx
rxfail
display_name
master
set acc_calibration = -11,28,286
set mag_hardware = NONE
set baro_hardware = NONE
set min_check = 1015
set max_check = 2000
set serialrx_provider = SBUS
set bat_capacity = 1500
set vbat_warning_cell_voltage = 345
set small_angle = 180
set deadband = 1
set pid_process_denom = 1
set osd_vbat_pos = 2434
set osd_tim_1_pos = 406
set osd_tim_2_pos = 406
set osd_remaining_time_estimate_pos = 33
set osd_flymode_pos = 2454
set osd_crosshairs_pos = 2253
set osd_mah_drawn_pos = 425
set osd_craft_name_pos = 332
set osd_warnings_pos = 2409
set osd_battery_usage_pos = 2440
set osd_stick_overlay_left_pos = 160
set osd_stick_overlay_right_pos = 182
set osd_stat_min_rssi = OFF
profile
profile 0
profile
profile 1
profile
profile 2
restore original profile selection
profile 2
rateprofile
rateprofile 0
set roll_srate = 75
set pitch_srate = 75
set yaw_srate = 80
rateprofile
rateprofile 1
rateprofile
rateprofile 2
rateprofile
rateprofile 3
rateprofile
rateprofile 4
rateprofile
rateprofile 5
restore original rateprofile selection
rateprofile 0
save configuration
save
